Quoting
Problems, glitches and suggestions for the management
Quoting
Postby SSC! » Thu Feb 06, 2014 5:02 pm
Am I being daft or is there no 'quoting' function? Working on Ipad and can't see the button. :shock:
SSC!
Re: Quoting
Postby OlberJ » Thu Feb 06, 2014 5:31 pm
It works as a hover with the mouse so you just need to touch the post and then the options will appear in the top right of the post.
Select quote and you're off! :geek:
Re: Quoting
Postby Angelus » Fri Feb 07, 2014 3:47 pm
SSC! wrote:Am I being daft or is there no 'quoting' function? Working on Ipad and can't see the button. :shock:
If you tap the screen about 3 or 4 mm to the left of the persons avatar, it should appear. For some reason it doesn't show on an iPad, but does if you use a windoze system...... :roll:
Re: Quoting
Postby OlberJ » Fri Feb 07, 2014 4:07 pm
It's the same on my tablet and phone, needs clicked before they appear.
or on the pc/laptop you need to hover over the post.
Re: Quoting
Postby shocks » Tue Feb 11, 2014 12:51 am
PEBCAK issue…..
Problem Exists Between Chair & Keyboard
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
shocks
Re: Quoting
Postby OlberJ » Tue Feb 11, 2014 10:06 am
IT Jokes :ugeek:
Return to Feedback and Issues
