Unlocking with key
Unlocking with key
Postby frag68 » Wed Nov 01, 2017 12:21 am
I've just bought a Boxster S and the car doesn't lock or unlock with the fob. I locked it with the key in the door but on unlocking the alarm went off and only went off when I turned on the ignition.
Is there a way to reset the key?
The key fobs both light up when pressed suggesting the battery in the fob is ok.
Looking to the TT collective for advice.
frag68
Re: Unlocking with key
Postby Andrew[MG] » Wed Nov 01, 2017 11:58 am
I can offer no assistance but would love some pics and to know the spec :-)
Postby Hoonmeister » Wed Nov 01, 2017 6:54 pm
Sounds like the key may need recoding.
Sadly it's the car that is coded to the key so bend over.
A good indie might do it...if not it's OPC.
Does the key start the car?
Hoonmeister
Postby frag68 » Wed Nov 01, 2017 7:27 pm
Once in the car I put the key in the ignition, turn it on and the alarm stops. Car starts no problem
I believe there is a system reset which can be done after a period of inactivity. Just need to find out what that is.
frag68
Postby OlberJ » Thu Nov 02, 2017 10:52 am
Same with our 986s.
As above, needs coded and it's dealer only afaik.
Return to Porsche Owners Scotland
