Headlight Restoration Kits
Postby m1key » Sat Aug 01, 2015 6:56 pm
Has anyone ever used one of the headlight restoration kits to get rid of lens oxidation/cloudiness etc?
Re: Headlight Restoration Kits
Postby Craig » Sat Aug 01, 2015 10:25 pm
Mikey I have not used the kit but had great results on the GTO using the meguiars polisher with a cutting pad and some compound, it took a while!
Craig
Postby Angelus » Sun Aug 02, 2015 9:31 am
Which car is it for Mike?
Postby m1key » Mon Aug 03, 2015 2:45 pm
Craig wrote:Mikey I have not used the kit but had great results on the GTO using the meguiars polisher with a cutting pad and some compound, it took a while!
Thanks Craig. I've got some Megs Ultimate Compound so could try that. Not got a polisher though so would be by hand.
Postby m1key » Mon Aug 03, 2015 2:46 pm
Angelus wrote:Which car is it for Mike?
The 350Z. They're not really bad but a bit cloudy.
Postby KB_S1 » Mon Aug 03, 2015 3:16 pm
I was about to ask about this too.
Top of the Scooby headlights getting that scaled/cloudy look.
Postby Angelus » Mon Aug 03, 2015 3:29 pm
Chairman of TIPEC just done his Jeep lights.
mine were dire the RH one doesn't show quite how bad in the pic because of the sun. I used a bucket of water with a squirt of washing up liquid in. Started with 800 wet n dry, then 1200-2000-2500. Then Auto Glym Paint renovator, finally finished off with AG Super Resin polish & then Rejex. All done manually took around 15-20 mins per light. You MUST rub in parallel lines not scrub in circles.
Postby KB_S1 » Mon Aug 03, 2015 4:08 pm
Were the results good?
Postby Angelus » Mon Aug 03, 2015 4:47 pm
Certainly helped. Could try on an old light from the scrappies first?
Return to Cleaning & Detailing
