Maserati summer detail
Postby highlander » Sat Apr 30, 2016 4:37 pm
Hi
Posted these pics on the Maserati forum but thought I should post them here too.
A day and half's work well spent I think ;) I used the kestrel DAS first with poor boy to remove last years polish and wax then chipex kit to touch up stone chips, again I then used the kestrel to apply 2 coats of meg's polish and finished off by hand with Harley's wax. Still to clean the wheels so will get to them over the week at some point.
highlander
Re: Maserati summer detail
Postby Angelus » Sat Apr 30, 2016 4:51 pm
Looking very good Gregg, if you've got time to do mine too? :D
Postby highlander » Sat Apr 30, 2016 5:44 pm
Angelus wrote:Looking very good Gregg, if you've got time to do mine too? :D
Sure! Just drop her off......might need to "test" the wax finish for a month or two though, so you can get her back in, say, September? ;)
highlander
Postby Hoonmeister » Sat Apr 30, 2016 8:15 pm
highlander wrote:Hi
Do you not use a sealant between polish and wax?
Hoonmeister
Postby highlander » Sat Apr 30, 2016 8:52 pm
No, should I? Still learning.
highlander
Postby Hoonmeister » Sat Apr 30, 2016 9:09 pm
What I now you could write on a pubic hair...
But I use a sealant...Autoglym. EGP before the HD wax. Seems to bead up a treat
Hoonmeister
Postby Craig » Sun May 01, 2016 4:33 pm
That looks great, I find it quite therapeutic getting the cleaning gear out. Peace and quiet away from all that x factor and the like crap on the telly these days
Craig
Postby allandwf » Wed May 11, 2016 10:49 pm
Come and do mine also, I've noticed a few bits needing sorted, she's looking good after the dent man worked his magic, bit a few scuffs, some small areas peeling lacquer, and I need to get the rear arches done again. Oh and sort out the scratched headlights, then she may look as well as Marci.
allandwf
Return to Cleaning & Detailing
