my terzo upgrade
my terzo upgrade
Postby terzo neil » Fri Jun 27, 2014 11:04 pm
right guys, had the car now 8 years so decided to freshen things up a bit
last years it was mapped by andyf with api ported headers and vf28 plus other goodies
so today
i have removed the following
engine, gearbox, front cradle, propshaft, gear linkage, rear subframe, diff and front brakes
also replaced all rear brake lines as rotten
so far i have fitted a new powder coated front subframe, ppg gearbox, all front suspension has been refitted
back end is sitting on the floor at present,
removed clutch and flywheel from old engine and cosworth baffle plate and ported headers and up pipe
removed turbo (vf28) which is being upgraded to a gt28
fitted new brakes as well removed the daft 294mm discs and 4 pots and replaced them with 335mm comp brakes just clear the speedlines by a fag paper
how it looked before i started
how look at mate garage on a 2 post ramp, nice and easy with all the toys of a garage including air tools
new front subframe already powder coated
now fitted
ppg gearbox now fitted
terzo neil
Re: my terzo upgrade
Postby tonytifoso » Sat Jun 28, 2014 2:18 pm
Looking forward to seeing it as no pictures visible mate.
tonytifoso
Postby m1key » Fri Aug 15, 2014 8:11 pm
How's this coming along?
Postby terzo neil » Sat Aug 16, 2014 7:00 am
maped yesterday but was setting up for high and low boost, now seems to be stuck in low boost of 1.2 bar when high boost is 1.65 bar
mapper is on the case will be sorted shortly
ecu reset done and file reloaded
now 1.63bar of boost on high setting and 1.1 bar on low boost
will be at the tt breakfast :)
terzo neil
